Inherit the number Jira Capture IIIN requirement as shown in the image.
ananias gutierrez carpio October 3, 2016
As setting the requirement number jira capture. because when creating a requirement impact the number re inherit the father. and now I believe in JIRA capture works. Help me solve.
image2016-10-3 17:51:9.png
Ignat
October 4, 2016
Hi Ananias,
To make the link picker work the same for the requirement number field, you would need a custom field 'Issue Picker'. Unfortunately this custom field type is not available in JIRA: https://jira.atlassian.com/browse/JRA-10666.
You can use only a plan text issue keys. Alternatively you can treat requirements as Epics (JIRA Agile) and use the Epic field that is supported in Capture for JIRA.
Ignat.
