Hi all,
I'm trying to import into multiple object types with only one import. In my case I have the object types PC and Software. And a PC can have references to multiple Software objects.
Both object types only have a name field. The PC type additionally has a reference to Software. Now what I want to do is import into both object types from the same import while also creating several referemced objects.
Say, I have the following simple Import file:
"name": "Computer 1",
"software": "SW1||SW2||SW3"
The name attribute will create a PC and all the values in the software attribute should creates Software objects. The current import configuration looks like this:
This creates the PC and an object with the name "SW1||SW2||SW3" in Software (without linking them).
How do I get Insight to create 3 individual Software objects and link them to the PC?
Since I control the import file, I can also apply changes there if necessary.
Regards
So, the final answer is: It is possible and works reliably.
You can also pass multiple attributes per object type:
"software": [
{"name": "SW1", "vendor": "MS"},
{"name": "SW2", "vendor": "MS"},
{"name": "SW3", "vendor": "Adobe"}
"computer": [
"software": "SW1||SW3"
And since everything is nicely together in one file, you only need one import configuration.
Well, You will not. :-) Here is a post from me, that could help you (subsequent imports need to be done), but as discussed with RIada - there are currently no options to CREATE referenced objects on imports - the only upgrade of this functionality they think of currently is maybe some sequencing imports to allow creating referenced objects first and then relate to them.
https://blog.valiantys.com/en/expert-tips/insight-for-jira
Thanks for your reply, but apparently you are wrong here. Let me explain:
"software": [
{"name": "SW1"},
{"name": "SW2"},
{"name": "SW3"},
{"name": "SW4"},
{"name": "SW5"},
{"name": "SW6"},
{"name": "SW7"},
{"name": "SW8"},
{"name": "SW9"},
{"name": "SW10"}
"computer": [
}Using this as an import file and setting up the mappings (Computer with selector = computer; Software with selector = software) will yield the expected results: After the import finishes, there will be 1 computer with 2 references to software.
When you clean out both object types, this can be reproduced several times.
Do you are doing EXACTLY what we have discuss with Riada - sequencing import. SW objects go first. Then you create PC with referencje to just create, but already EXISTING SW objects. :)
