Insight Object schema import type - Object Mapping
Giovanni Salvagno June 25, 2020
Hello,  I need to import objects from an Insight schema to another one ( on the same server ).
I successfully configure the Object Import Schema, following this page. But I cannot create an Object Type Mapping. I can't find any information.
Data Locator is always empty.
How to set "Selector" and/or "Filter data source by IQL field" in order to get the objects from the source Schema  ? Any example ?
Hana Kučerová
October 18, 2020 edited
Hi @Giovanni Salvagno ,
I've just solved the same thing today.
Field Selector is a little bit tricky. It should look like this: User Office;123
  • User Office = name of the object type in the source scheme
  • 123 = id of the object type in the source scheme
Let me know, if there is anything else I can help you with.
