Insight discovery import error
LAURENT Didier
April 15, 2021
The import does not work since 2 days:
No error returned on the page .
When I clic on synchronise :  he says Started 17 days Ago:
I stop and reclic on synchronis :  Error Progress already strated for progress ID: progess id: ressourcid 7, category: imports
What could I do to stop this procces. Where can i stop this process ?
Manuela April 22, 2024
In my case after 2h i got the message: Exeption progress is cancelled
Than I've made manual import (normally I use scheduled cron import - User Import) and all worked fine
Cristian Iorio
Same here. This happened after a previous import ended with errors.
Ariel.Prado June 10, 2021
I am facing the same. At first the fix was restart jira.
But now cant Import Users form JIra.
Could you fix it?
Regards
