Insight -printing multiple labels
Arkadiusz Baka
August 3, 2021 edited
Is there any solution to print a multiple labels on one page ? Now I can only print one label per page from template
Tom Martin
September 9, 2021
Yes, you need to go to search and filter on the objects you want to print then select a bulk action and print labels. if the label are sized correctly they will fit multiple on one page
