Integration of Jira & symphony Summit
Amol Dongare
October 24, 2019
Hi Community,
Is there any integration is possible between Jira & symphony Summit (IT Ops management) with any existing marketplace plugin?
Or how we can achieve this using REST API?
Dario B
October 25, 2019 edited
Hi @Amol Dongare,
I have searched the marketplace but I haven't found much. On the other hand, widening a bit the research, I have found the below results but I am not sure it is the same symphony:
Can you kindly review above links and see if they are related/helpful?
Dario
Shailesh Dhawale October 30, 2019
@Dario
we want integration between Jira & symphony Summit
you shared that link which is ok but that symphony is different
Dario B
October 30, 2019
Hi @Shailesh Dhawale ,
If that's a different software then I haven't found anything useful. You may want to ask the vendor for available integrations or plugins.
However, having the right skill-set and starting from the assumption that Symphony Summit provides APIs to integrate, you can build the integration by yourself.
Please see below documentation pages for details (for both, Server and Cloud):
I hope this helps.
Dario
Like • Dario B likes this
hemanth kumar March 5, 2020
Have anyone found solution to this issue.
please help us.
John Walls
April 5, 2023
Hi, did anyone build an API for this integration?
