Integration with redmine
Marija Kuzmina
Hi everyone. I need to realise integration between jira and redmine. I mean I would like to send some issue from jira to redmine and to get information about issue's status if it changes. Is it possible?
Al Sko June 8, 2012
Task Adapter can transfer data between Jira and Redmine. It's not exactly what you need (it can't auto-update task statuses when they are changed), but you can transfer (create/update) tasks manually
Ivar
December 20, 2011
Have you checked out Jira's interfaces for integration: https://developer.atlassian.com/display/JIRADEV/JIRA+RPC+Services ? I cannot answer on behalf of Redmine, but I believe you should be able to get what you need from Jira.
Marija Kuzmina
Ivar, thanks! I'll try to use it
Ivar
December 20, 2011
Feel free to accept my answer if you feel it is good enough :)
張旭 Zx
June 3, 2018
There is no official plugin for this !?
Nic Brough -Adaptavist-
June 4, 2018
No.  Most people with Redmine and Jira don't want to "integrate", they want to migrate from Redmine to Jira.  So there are importers, but no "integration" add-ons, as there's no demand for them.
Like • Anton Skopintsev likes this
