Integrity Check: Check for duplicate permissions. How can I find these ID's?
Sandra Meessen
Hello, When running the Jira Integrity Check "Check for duplicate permissions" I get several findings:
Check duplicate permissions.JPG How do I find these ID's/Permission Schemes? Is it save to just click "Fix"? Thank you for the help.
Nic Brough -Adaptavist-
April 30, 2018
Yes, clicking "fix" is the best thing to do here.
It's perfectly safe as duplicates can't be in use anywhere in more recent Jira versions (it's a long dull explanation which you really don't need).   You don't need to worry about finding these or understanding what they are in any detail.
If you are worried about it, then take a backup before running the fix routine, but I wouldn't bother.
