Every day we are facing a bug in the jira, whenever we create a new Task and create the link with an "Epic" the error appears in "Epic" and we are blocked to create new cards.
Every day we make the corrections and the error returns.
What could be causing this error?
Follow the image with the error.
You should examine your atlassian-jira.log in the moments of the error. You will see the cause of the error
I performed a search for errors with the "integrity checker" of the jira and the error that appeared was the following;
But even after correcting the above error it returns a time later.
You should see your atlassian-jira.log for the error. Integrity checker does not check all the errors. Your error can be not related to the checks which are performed by the integrity checker.
