×Hi All,
We currently have our JIRA instance (Server-Core) hosted on AWS. For some reason, whenever someone uploads something .jpeg, .png, .mp4 etc. that is about 10mb or equivalent. It fails. We have an NGINX proxy which is set to unlimited and on JIRA it is set to 2GB but it still fails.
I have searched numerous searches on here and Google, but I can't find a definite answer. I had previously contacted Atlassian Support, but they wanted a copy of our JIRA, which a bit much if you ask me just to troubleshoot this issue.
Anyone with a similar setup as myself, can provide any insight? Keep in mind it is hosted on AWS using the server core option.
We'll need to see the logs for the time at which the errors occur.
There is nothing useful in the logs. Something similar to this, but running on NGINX proxy: https://confluence.atlassian.com/jirakb/unable-to-upload-large-attachment-even-when-attachment-file-size-limit-exceeds-it-815242350.html
It seems somehow NGINX is still preventing it. Getting Error Code: 413 in console mode from the browser.
Ok, that makes sense. A 413 error means "whatever the http(s) stream we are handling, it is too big". Most browsers do not have any code to do capping that would cause a 413, but web-servers all do, and most set a limit by default (to prevent load and overloading attacks by default)
Your nginx server is the culprit here, it's got a cap (presumably of 5Mb) on uploads. You'll need to increase that cap.
This Hi @Steven Camilleri
try going to cog/General Configuration and editing the Attachment Maximum Size
also check NGINX limits
https://www.cyberciti.biz/faq/linux-unix-bsd-nginx-413-request-entity-too-large/
