Internal directory nested group memberships not applied to LDAP users?
angel
Are nested group memberships maintained for groups in a local directory not applied to users from an LDAP (AD) directory?
We would like to apply nested group memberships in local groups for users coming from an LDAP directory (setup as Read Only, with Local Groups). It seems that group memberships work for local users but not for remote directory users. (JIRA 6.2.x)
Gregory Kneller
November 21, 2014
Hi @Tiago Comasseto, I guess it is not about nesting LDAP groups into internal groups
I have described use case here Why nesting of internal groups does not work for AD users?
Nesting does not work for a user, who is from LDAP. Let us consider that   a user A is a member of some internal group G1, and this internal group is nested in another internal group G. If user A is from internal directory, he is  a member of G1 and G, but if he is from LDAP directory, he is a member of ONLY G1.
This situation is only for JIRA. If JIRA is used as a directory provider for Confluence, you may find that A is a member of both  G1 and G in Confluence, whether A is originally from LDAP or from JIRA internal
It means, nesting really cannot work in JIRA, if one uses a  LDAP directory along with internal groups, and it looks as a JRA bug.
Gregory Kneller
December 30, 2014
This is due to bug https://jira.atlassian.com/browse/JRA-24671
The following workaround helped me.
1. Remove all existing group nesting in JIRA. If it does not work, disable nesting in (one of) your external directory and try to remove nesting again*.
2. Enable group nesting for all directories.
3. Group nesting shall work as expected
 *If you unable to do 1, just perform the ultimate hack
1. Run over JIRA database
delete from cwd_membership where membership_type='GROUP_GROUP';
commit;
Then you may need to restart JIRA
angel
Hi Tiago,
I'm aware and already watching the improvement you mention, but what I was looking for is adding AD/LDAP users as members of local directory groups which are structured as nested groups. This is supported by JIRA but there is a catch. All the nesting should be performed by an administrator user which belongs to the external directory (AD/LDAP) and not a local administrator, for nesting to work correctly.
We discussed this with support and hopefully they are going to write a KB article to explain this constraint. You can follow the details in JSP-194321 if you can get access.
I still believe that this is a bug, but guys from support argue that is works as designed. Maybe the design is a bit flawed after all.
Cheers
Tiago Comasseto
June 22, 2014
Hi Anggelos, we currently don't support nested membership between internal and external groups. We have this improvement request opened to implement this functionality in a future release, you may want to add yourself as watcher to receive updated.
Cheers
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
