Is JIRA supported on WebLogic 10.3.5 ?
Sameera Shaakunthala [inactive]
August 21, 2012
We are currently checking whether we can run JIRA on Oracle WebLogic 10.3.5 . We were unable to start JIRA and we observed the following stacktrace during 'Starting Plugin System' phase. We are not sure if JIRA 4.3.2 is supported on WebLogic 10.3.5 .
2012-08-23 18:32:09,969 [ACTIVE] ExecuteThread: '0' for queue: 'weblogic.kernel.Default (self-tuning)' ERROR admin 1112x25x2 6qbfoc 192.168.30.210 /rest/gadget/1.0/project/generate [atlassian.plugin.servlet.DefaultServletModuleManager] Unable to create filter
com.atlassian.util.concurrent.LazyReference$InitializationException: com.sun.jersey.api.container.ContainerException: Unable to create resource
        at com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:152)
        at com.atlassian.util.concurrent.LazyReference.get(LazyReference.java:115)
        at com.atlassian.plugin.servlet.DefaultServletModuleManager.getFilter(DefaultServletModuleManager.java:358)
        at com.atlassian.plugin.servlet.DefaultServletModuleManager.getFilters(DefaultServletModuleManager.java:212)
        at com.atlassian.plugins.rest.module.servlet.DefaultRestServletModuleManager.getFilters(DefaultRestServletModuleManager.java:117)
        at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:75)
        at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:63)
        at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:74)
        at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:42)
        at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:66)
        at com.atlassian.plugins.rest.module.servlet.RestServletUtilsUpdaterFilter.doFilterInternal(RestServletUtilsUpdaterFilter.java:26)
        at com.atlassian.plugins.rest.module.servlet.RestServletUtilsUpdaterFilter.doFilter(RestServletUtilsUpdaterFilter.java:40)
        at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:25)
        at com.atlassian.plugin.servlet.filter.ServletFilterModuleContainerFilter.doFilter(ServletFilterModuleContainerFilter.java:77)
        at weblogic.servlet.internal.FilterChainImpl.doFilter(FilterChainImpl.java:56)
        at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.executeRequest(AccessLogFilter.java:102)
        at com.atlassian.jira.web.filters.accesslog.AccessLogFilter.doFilter(AccessLogFilter.java:86)
        at com.atlassian.jira.security.xsrf.XsrfTokenAdditionRequestFilter.doFilter(XsrfTokenAdditionRequestFilter.java:50)
        at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:46)
        at com.quisapps.jira.fieldsecurity.filter.FieldSecurityFilter.doFilter(FieldSecurityFilter.java:60)
        at com.atlassian.seraph.filter.SecurityFilter.doFilter(SecurityFilter.java:210)
        at com.atlassian.security.auth.trustedapps.filter.TrustedApplicationsFilter.doFilter(TrustedApplicationsFilter.java:98)
        at com.atlassian.seraph.filter.BaseLoginFilter.doFilter(BaseLoginFilter.java:144)
        at com.atlassian.jira.web.filters.JiraLoginFilter.doFilter(JiraLoginFilter.java:70)
        at com.atlassian.oauth.serviceprovider.internal.servlet.OAuthFilter.doFilter(OAuthFilter.java:71)
        at com.atlassian.plugins.rest.module.servlet.RestSeraphFilter.doFilter(RestSeraphFilter.java:40)
        at com.atlassian.jira.web.filters.ActionCleanupDelayFilter.doFilter(ActionCleanupDelayFilter.java:59)
        at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:31)
        at com.atlassian.jira.web.filters.RequestCleanupFilter.doFilter(RequestCleanupFilter.java:53)
        at com.atlassian.johnson.filters.AbstractJohnsonFilter.doFilter(AbstractJohnsonFilter.java:71)
        at org.tuckey.web.filters.urlrewrite.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:350)
        at com.atlassian.gzipfilter.GzipFilter.doFilterInternal(GzipFilter.java:81)
        at com.atlassian.gzipfilter.GzipFilter.doFilter(GzipFilter.java:51)
        at com.atlassian.core.filters.cache.AbstractCachingFilter.doFilter(AbstractCachingFilter.java:33)
        at com.atlassian.core.filters.encoding.AbstractEncodingFilter.doFilter(AbstractEncodingFilter.java:41)
        at com.atlassian.jira.web.filters.PathMatchingEncodingFilter.doFilter(PathMatchingEncodingFilter.java:45)
        at com.atlassian.jira.web.monitor.ActiveRequestsFilter$PassToChainFilterFunc.doFilter(ActiveRequestsFilter.java:346)
        at com.atlassian.jira.web.monitor.ActiveRequestsFilter$DebugLogFilterFunc.doFilter(ActiveRequestsFilter.java:463)
        at com.atlassian.jira.web.monitor.ActiveRequestsFilter.doFilter(ActiveRequestsFilter.java:173)
        at com.atlassian.jira.startup.JiraStartupChecklistFilter.doFilter(JiraStartupChecklistFilter.java:76)
       at com.atlassian.multitenant.servlet.MultiTenantServletFilter.doFilter(MultiTenantServletFilter.java:91)
        at com.atlassian.jira.web.filters.JiraFirstFilter.doFilter(JiraFirstFilter.java:67)
        at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.wrapRun(WebAppServletContext.java:3715)
        at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java:3681)
        at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
        at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:120)
        at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2277)
        at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2183)
        at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1454)
        at weblogic.work.ExecuteThread.execute(ExecuteThread.java:209)
        at weblogic.work.ExecuteThread.run(ExecuteThread.java:178)
Caused by: com.sun.jersey.api.container.ContainerException: Unable to create resource
        at com.sun.jersey.server.impl.resource.SingletonFactory$Singleton.init(SingletonFactory.java:131)
        at com.sun.jersey.server.impl.model.ResourceClass.init(ResourceClass.java:200)
        at com.sun.jersey.server.impl.application.WebApplicationImpl.getResourceClass(WebApplicationImpl.java:315)
        at com.sun.jersey.server.impl.application.WebApplicationImpl.initWadlResource(WebApplicationImpl.java:844)
        at com.sun.jersey.server.impl.application.WebApplicationImpl.processRootResources(WebApplicationImpl.java:815)
        at com.sun.jersey.server.impl.application.WebApplicationImpl.initiate(WebApplicationImpl.java:590)
        at com.atlassian.plugins.rest.module.RestDelegatingServletFilter$JerseyOsgiServletContainer.initiate(RestDelegatingServletFilter.java:134)
        at com.sun.jersey.spi.container.servlet.ServletContainer$InternalWebComponent.initiate(ServletContainer.java:242)
        at com.sun.jersey.spi.container.servlet.WebComponent.load(WebComponent.java:449)
        at com.sun.jersey.spi.container.servlet.WebComponent.init(WebComponent.java:169)
        at com.sun.jersey.spi.container.servlet.ServletContainer.init(ServletContainer.java:281)
        at com.sun.jersey.spi.container.servlet.ServletContainer.init(ServletContainer.java:599)
        at com.atlassian.plugins.rest.module.RestDelegatingServletFilter.init(RestDelegatingServletFilter.java:48)
        at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.init(DelegatingPluginFilter.java:43)
        at com.atlassian.plugin.servlet.DefaultServletModuleManager$LazyLoadedFilterReference.create(DefaultServletModuleManager.java:411)
        at com.atlassian.plugin.servlet.DefaultServletModuleManager$LazyLoadedFilterReference.create(DefaultServletModuleManager.java:396)
        at com.atlassian.util.concurrent.LazyReference$Sync.run(LazyReference.java:326)
        at com.atlassian.util.concurrent.LazyReference.getInterruptibly(LazyReference.java:146)
        ... 96 more
Caused by: java.lang.reflect.InvocationTargetException
        at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
        at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:39)
        at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:27)
        at java.lang.reflect.Constructor.newInstance(Constructor.java:513)
        at com.sun.jersey.server.spi.component.ResourceComponentConstructor._construct(ResourceComponentConstructor.java:173)
        at com.sun.jersey.server.spi.component.ResourceComponentConstructor.construct(ResourceComponentConstructor.java:155)
        at com.sun.jersey.server.impl.resource.SingletonFactory$Singleton.init(SingletonFactory.java:129)
        ... 113 more
Caused by: java.lang.LinkageError: loader constraint violation: when resolving method "javax.xml.bind.JAXBElement.<init>(Ljavax/xml/namespace/QName;Ljava/lang/Class;Ljava/lang/Object;)V" the class loader (instance of org/apache/felix/framework/ModuleImpl$ModuleClassLoader) of the current class, com/sun/jersey/server/wadl/WadlGeneratorImpl, and the class loader (instance of <bootloader>) for resolved class, javax/xml/bind/JAXBElement, have different Class objects for the type javax/xml/namespace/QName used in the signature
        at com.sun.jersey.server.wadl.WadlGeneratorImpl.createResponse(WadlGeneratorImpl.java:176)
        at com.sun.jersey.server.wadl.WadlBuilder.generateResponse(WadlBuilder.java:351)
        at com.sun.jersey.server.wadl.WadlBuilder.generateMethod(WadlBuilder.java:161)
        at com.sun.jersey.server.wadl.WadlBuilder.generateResource(WadlBuilder.java:291)
        at com.sun.jersey.server.wadl.WadlBuilder.generate(WadlBuilder.java:102)
        at com.sun.jersey.server.impl.wadl.WadlApplicationContextImpl.getApplication(WadlApplicationContextImpl.java:73)
        at com.sun.jersey.server.impl.wadl.WadlResource.<init>(WadlResource.java:73)
        ... 120 more
Following is also added to weblogic.xml in WEB-INF directory.
<container-descriptor>
<prefer-web-inf-classes>true</prefer-web-inf-classes>
</container-descriptor>
Shaakunthala
Nic Brough -Adaptavist-
August 21, 2012
Supported, no, Atlassian only support it on Tomcat.
It is possible though - I've recently seen it running fine on Weblogic 10.something. I'm not sure I can help you with it, as it wasn't my setup and I'm not in touch with the chap who built it.
August 21, 2012
In the Atlassian's support system, it looks like WebLogic 7.0.x, 8.x & 9.x are supported, but not 10.x . Are they likely to provide WebLogic support in future?
August 21, 2012
Er, no, they've explicitly stated that Tomcat is the only application server they can officially support and dropped all the others as of Jira 4.2. There is no harm in asking though - they WILL try to help you, even though they may well end up with "move it to Tomcat and try again" if they are stuck.
See https://confluence.atlassian.com/display/JIRA/End+of+Support+Announcements+for+JIRA#EndofSupportAnnouncementsforJIRA-DeprecatedApplicationServersforJIRA(27January2010)
August 21, 2012
Thanks Nic!
Hope Atlassian would re-consider WebLogic in future. :)
Register today
