Hi Niclas ,
Thanks for your reply , we are migrating our database to Oracle 12 c .
Do you have any clue that what will happen when this process is completed ?
Thanks in advance
Ashutosh
It's hard to speculate do a lot of testing!
I suspect it's going to fail. The problem is that you're going to need a slightly more recent jdbc driver than works on the version of Java you need to run for JIRA 5.2.
It might work, but you'll need to do extensive testing with a mix of java and jdbc drivers that are not expected to work properly.
I would not bother. I would upgrade JIRA to a supported version.
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
