Is Jira certified to SQL Server 2012 SP4?
Jose Augusto de Jesus Germano February 23, 2018
I'm doing a study to apply the cumulative update packages from SQL Server 2012 to SP4, but in Jira's matrix I did not find that it is homologated. Is anyone in SP4 and have any comments? Does it work smoothly?
Link of matrix:  https://confluence.atlassian.com/adminjiraserver071/supported-platforms-802592168.html
Peter DeWitt
February 23, 2018
@Jose Augusto de Jesus Germano, We currently run that configuration for our DB so it will work fine for you.  Performance is good just make sure you have enough resources on the server to support it.  As an aside, while 2012 supports clustering you will need to manually fail it over.  2014 will provide you with true HA.
pjd
Jose Augusto de Jesus Germano February 26, 2018
Thanks, @Peter DeWitt. I will try to implement this Service Pack. I was safer now.
Nic Brough -Adaptavist-
February 23, 2018
All the service packs are supported.
Good information, @Nic Brough -Adaptavist-. Thanks
