Is Multilevel Cascade Select 2.5 compatible with Jira v5.0?
Stephan Haertel May 23, 2012
great plugin, but we have JIRA v5.0 and I am reluctant to just try it out.
Regards
Ivan Tse
September 18, 2012
I ran across this thread while looking for updates on the plugin. I wanted to let everyone here know that it looks like the developer did update for JIRA 5.
http://sourcesense.github.com/jira-multi-level-cascade-select/downloads.html
I'm not entirely sure if it is compatible with JIRA 5.1.x though.
Note: Doesn't look like the dev updated their plugin on the marketplace so you'll need to grab it manually from the link above.
Stephan Haertel October 9, 2012
Thanks for that info!
Ramiro Pointis
June 1, 2012
I'll highly recommend to write the vendor plugin to the mail he shows on the plugin page:
atlassian@sourcesense.com
I'm pretty sure you will have a quicker response and a more specific one too ;)
Ramesh Udari1
i have tried to install 2.5 version and every thing went fine, but we try to see customfield values in create page screen parent value is not showing, insted it is showing reference velocity code in dropdown. and getting below error in log.
013-08-12 10:47:06,776 http-8080-Processor15 WARN ramesh.udari 647x181x1 143nuwi 172.17.82.51 /secure/CreateIssue.jspa [velocity] org.apache.velocity.runtime.exception.ReferenceException: reference : template = templates/plugins/customfield/multi-level-cascading-select-edit.vm [line 49,column 46] : $cfValueEncoder.encodeForHtml($option.value) is not a valid reference.
at org.apache.velocity.runtime.parser.node.ASTReference.render(ASTReference.java:277)
at org.apache.velocity.runtime.parser.node.ASTBlock.render(ASTBlock.java:55)
at org.apache.velocity.runtime.directive.Foreach.render(Foreach.java:166)
at org.apache.velocity.runtime.parser.node.ASTDirective.render(ASTDirective.java:114)
at org.apache.velocity.runtime.parser.node.ASTIfStatement.render(ASTIfStatement.java:70)
at org.apache.velocity.runtime.parser.node.SimpleNode.render(SimpleNode.java:230)
at org.apache.velocity.Template.merge(Template.java:256)
at org.apache.velocity.app.VelocityEngine.mergeTemplate(VelocityEngine.java:422)
at com.atlassian.velocity.DefaultVelocityManager.getEncodedBody(DefaultVelocityManager.java:77)
at com.atlassian.velocity.DefaultVelocityManager.getEncodedBody(DefaultVelocityManager.java:61)
at com.atlassian.velocity.DefaultVelocityManager.getEncodedBody(DefaultVelocityManager.java:56)
at com.atlassian.jira.plugin.AbstractJiraModuleDescriptor.getHtml(AbstractJiraModuleDescriptor.java:109)
Saneth Kumar
I contacted the vendors (Sourcesense Europe), they said that it's still in the pipeline.
Aviva Yechezkel June 25, 2012
Is there any movement on this? We are highly dependant on this plugin.....
Saneth Kumar
Did they reply? I emailed them a few hours back but still haven't got a reply.
Janaki Kora May 31, 2012
Hello:-
Even I am looking for an Answer to this question. We are currently on JIRA 4.4 and am planning to upgrade to 5.1.x.
Rgrds
Hello:-
Rgrds
Carsten Beck-Astrup
I also would like to know when this plugin is updated to 5.0.x.
