×Hi, Is anyone experiencing weird behaviour in Jira Cloud?
On the 13th April we had issue where the Story issue type was removed from all Issue Schemes affecting all projects. I can't see how this can be done by accident without an admin needing to go into every single issue scheme and removing it.
on the 16th we have another issue where sprints stopped working for a specific project. I've now had to manually assign our default field configuration scheme which some how appears to have fixed this.
We've even got significant weirdness where the Default Issue Scheme doesn't even have Stories or bugs which should be default Jira issue types... (I've attached pictures below)
Any help would be awesome!!!
Hi Peter, seems like your JIRA is affected by this bug https://jira.atlassian.com/browse/JRACLOUD-69284 though it has been marked resolved you might want to check with support if you are still experiencing the problem.
Thanks Nazri, that definitely looks like my problem.
Looks like the unfortunate approach of manually adding it back is what the other person affected had to do too.
Register Now
