Is it possible for locating all the subtask's attachments in a single zip folder in jira?
Sushma May 6, 2019
I want to get all the subtask's attachments in a single zip folder.is it possible?
Thanks in advance.
Sushma
Nic Brough -Adaptavist-
May 6, 2019
Not directly from the UI, and you can't do it easily directly on the server.  They are kept in one directory (per issue), but not with the names you see on-screen.
To get a zip of all attachments, you should scrape the issue with REST and build the archive in a script.
Sushma May 28, 2019 edited
Hi Nic
is it possible to make "Labels"field as non editable in the view screen?
Sushma
def descField = getFieldById("Labels")
descField.setAllowInlineEdit(false)
Sushma May 28, 2019
The above code is not working
I am using jira version v7.10.1 and script runner v. 5.5.6
Learn more
