Is it possible to add a custom gadget to the JIRA dashboard (google analytics)?
Justin Corcoran
March 20, 2012
Specifically, I'd like to add one or more gadgets that would display charts from Google Analytics. Is there an existing plugin to add this type of gadget to the dashboard, and/or is it possible to create custom gadgets that can be added to the dashboard?
Addown Support
Hi there, for anyone who is still looking for a solution, I would like to recommend our app jFrame, which allows you to embed different types of content as Jira cloud dashboard gadgets, including Data Studio reports (based on Google Analytics data), Google sheets and slides and more from other vendors as well (Power BI, Figma etc.).
Hope this helps. Good luck!
Justin Corcoran
March 20, 2012
I guess technically we're looking to add graphs using Google Graphing, not necessarilly google analytics.
Learn more
