×This is my goal i need to update the external database whenever a ticket is raise in jira.
Event has been triggered then script will run to update a table in MS SQL server . Anyone know how to do it or to put the jdbc for sql server in JIRA files?
note: Our Jira is in Mysql.
What plugin do you use from quering your database? Usually you put additional libraries to the lib folder of you Jira.
Hi alex,
I will use a groovy script runner.
import groovy.sql.*;
import java.sql.Connection;
import java.sql.DriverManager;
import java.sql.ResultSet;
import java.sql.Statement;
def sql = Sql.newInstance('jdbc:sqlserver://localhost:port;databaseName=dbName', 'username',
'password', 'com.microsoft.jdbc.sqlserver.SQLServerDriver')
sql.execute("INSERT INTO table(testcolumn) VALUES ('test value')");
sql.close()
and here is the error:
2018-03-09 14:37:48,323 WARN [common.UserScriptEndpoint]: Script console script failed: java.lang.ClassNotFoundException: com.microsoft.jdbc.sqlserver.SQLServerDriver not found by com.onresolve.jira.groovy.groovyrunner [198] at org.apache.felix.framework.BundleWiringImpl.findClassOrResourceByDelegation(BundleWiringImpl.java:1532) at org.apache.felix.framework.BundleWiringImpl.access$400(BundleWiringImpl.java:75) at org.apache.felix.framework.BundleWiringImpl$BundleClassLoader.loadClass(BundleWiringImpl.java:1955) at Script21.run(Script21.groovy:7)
My external db is MS SQL SERVER 2008 R2
and i use sqljdbc64.jar i place it under JIRA_HOME/lib directory
what was wrong with this?
Thank you,
Randy
You need to put your driver into the lib folder of you Jira and restart your Jira.
Kindly have a look at the page on how to query databases from ScriptRunner:
https://scriptrunner.adaptavist.com/5.3.7/jira/recipes/misc/connecting-to-databases.html
i also tried that sample and it is still got the same error.
Im just curious where to put the driver is it in JIRA_HOME/lib? or maybe in different lib?
As far as I understand you created the lib directory? I do not have access right now to Jira. But I think the lib folder is situated in the Jira_installation folder. It must be already available in your Jira instances. And there must be already drivers for some databases.
No i didn't create a directory. sorry for the misunderstanding i just put the driver in the jira_installation lib directory
here is the driver where i download it:https://www.microsoft.com/en-us/download/details.aspx?id=56615
and the jar file in the extracted folder is the only file that i move to JIRA\lib
and here is my code for the scriptrunner sample
import groovy.sql.Sql
def driver = Class.forName('com.microsoft.jdbc.sqlserver.SQLServerDriver').newInstance() as Driver
def props = new Properties()
props.setProperty("user", "username")
props.setProperty("password", "password")
def conn = driver.connect("jdbc:sqlserver://localhost:port;databaseName=dbName", props)
def sql = new Sql(conn)
try {
sql.eachRow("select * from table_name") {
log.debug(it)
} finally {
sql.close()
conn.close()
and i got this error:
2018-03-09 15:17:54,946 WARN [common.UserScriptEndpoint]: Script console script failed: java.lang.ClassNotFoundException: com.microsoft.jdbc.sqlserver.SQLServerDriver at Script33.run(Script33.groovy:4)
Thank you,
Randy
Kindly read the following post
The lib folder in
C:\Program Files\Atlassian\JIRA\lib directory
I already read that link but didnt see the bottom page. haha thanks bro now i have a different error but i think i can handle it now because i already know that the driver is now working.
Error
The TCP/IP connection to the host prot/dbname, port 1433 has failed. Error: "null. Verify the connection properties. Make sure that an instance of SQL Server is running on the host and accepting TCP/IP connections at the port. Make sure that TCP connections to the port are not blocked by a firewall.".
