×I am trying to restrict the view of GroupM on tickets within the project based on the value of custom field 'Client'.
Conditions:
If Client is not ABC, ticket can be viewed by anyone including GroupM users
If Client is ABC, All users except GroupM are able to view the ticket.
I was able to configure Issue Security successfully before similar to this but its the other way around - if Client is ABC, only GroupM can view the ticket. If Client is not ABC, anyone can view the ticket.
I am trying to find out if there is a way for me to reconfigure the issue security scheme I have setup to use except GroupM instead of only GroupM when the Client is ABC.
Thanks in advance for any help :)
No, there's no way to do this. Permissions in Jira are completely permissive, not exclusive.
Hi @Nic Brough -Adaptavist- and @Rilwan Ahmed
Just an update on this one. I ended up just using the default Issue security setup. Took a while to complete but meets my client's requirements.
I added all users except the restricted ones into GroupA then added the post function that sets the security level 'GroupAOnly' in ticket if it is for Client ABC. The restricted users then can only view tickets that are not for Client ABC.
Hi @Sha Aquino ,
There is no direct way to achieve this. But manually you can do my making use of Issue Security schemes.
i.e.
That's still the same problem.
Let's say you've got several groups of people, all of whom have "browse project"
Security schemes let you say "only group X can see this issue when security level is set to Y".
But Sha A wants to be able to say "Group X can NOT see the issue when security level is set to Y".
With both permissions and security levels, the only way you can do that is to say "groups A, B, C, D ...... W, Y and Z can see it" - leaving X off the list. This gives you the problem that if you add a new group who should be able to see the issues, then you have to amend the scheme every time!
Thanks for the suggestion. I think it would be possible if we only have a few users/ groups. The project is open to all who has access to jira and we have around 50+ groups.
I agree with @Nic Brough -Adaptavist- as it may be a very tedious process to maintain just for 1 project.
Thank you though 🙂
Hi @Sha Aquino
One more turnaround if your project uses project roles in the permission schemes rather than groups directly, then
I think you might have something here. I’ll look into this and try it. I may need to add some adjustments and make use of project roles in the permission schemes since it does not use it.
Thank you! I’ll post updates on what I get after testing. 🙂
