Sign up Log in
Is it possible to change the default settings for the fields checked in the "Configure Fields" menu?
Maggie Stearns
When editing an issues in JIRA, if I click on the "Configure Fields:" button in the top right-hand corner, a set of fields is checked. How does that set get defined? I can see that it remembers me settings, but I'm wondering how it gets defined at the beginning.
Deleted user March 15, 2016
AFAIK, everything is checked by default.
Deleted user June 25, 2019
I just created a new issue type (subtask) and added it to my existing issue type screen scheme so it would be available to all of my projects. I also created a new screen and screen scheme.
When I try to create a new subtask, only the system fields are showing up (e.g., summary, description, components, labels, assignee, etc.) and my custom fields, from my new screen, are not showing up by default.
It appears from this question; https://community.atlassian.com/t5/Jira-questions/User-s-quot-Configure-Fields-quot-settings/qaq-p/43816, that the default is to only show the system fields and not all fields. :(
Is there a way to force a new issue type and new screen to show All fields to all users the first time they use that new issue type? And then allow them to turn off any fields they don't want to see after that?
clem
April 20, 2016
I'm also wondering where these settings are saved.
Cynthia
Deleted user April 20, 2016
