After the regular upgrade of the JIRA Subversion plugin, I found out that the old synchronization service became deprecated. Now I couldn't find any ways to change the synchronization period - it was set to 60 minutes by default.
Is there some settings to do this?
Hi Michael, you can edit the synchronization internal at JIRA services. There you'll see a service called com.atlassian.jira.plugin.ext.subversion.revisions.scheduling.UpdateIndexMonitorImpl:job, you just need to edit it to the period of your choice.
Cheers
I asked this question because that service's behavior is a bit weird: by default it has 3 parameters, but when I try ot edit the service, I don't see any of them at the configuration screen.
Do you know, is this behavior is expected? And what do those parameters mean?
