×I am talking about gadget columns, not navigator columns. I don't mean choosing from one of the preset layouts but shrink the columns by a custom percentage.
At this moment, it's not possible to achieve this in JIRA.
Pedro
You can use the chome Stylish plugin to override UI for many parts of Crucible, JIRA, etc. However, I cannot seem to override the column widths for gadgets. I'd love the ability to set the min width %, set white space to normal on gadget filter result table header, and potentially adjust the padding.
We still need help with this, as far as I know. The latest upgrade has made some columns break on hyphens and be way too narrow.
Just wondering if this status has changed?
It'd be great to be able to vary the size of gadgets on a dashboard.
Have we had any answers yet since April? I want to know it is possible now or not.
up
Isn't it possible to e.g. create a custom layout in which you can put gatget wherever you want and customize its size? Just like a folder on a desktop...
