Is it possible to copy worklog description to comment?
cedricboivin@nmediasolutions.com
Hello, I want to copy worklog description to comment issue. Is it possible ?
AmandaA
June 4, 2013
By default when you log work, the Log Work tabpanel contain the Work Description, but it's not a comment field, it is mean to be discribe the Work.
If you want to add the Comment field into this panel, you need to edit the system plugin in the .vm file level. Which you need to find
Installation_dir\atlassian-jira\WEB-INF\classes\templates\plugins\jira\issuetabpanels\worklog.vm
Phillip Ponzer [Cprime]
January 26, 2015
Is there a way to do this without editing the Velocity template?
katerina_zelenkova July 1, 2020
is there currently any possibility to do this (copy worklog description to comment) in cloud version?
Thank you in advance.
Deniz OÄŸuz - The Starware
May 30, 2017
We have added this capability to WorklogPRO's log work dialog.
Tehno Bear June 14, 2015
Please check this plugin. May be it is what you need. It will copy Work Description to Comment field.
https://marketplace.atlassian.com/plugins/ru.tehnobear.copy_work_description_to_comment
Sophie Mongeon
January 10, 2018
And for Cloud version, is there is a solution or a plugin?
Tehno Bear March 27, 2016
Hello! You can try this plugin. It will auto copy Work Description to Comment field.
https://marketplace.atlassian.com/plugins/ru.tehnobear.copy_work_description_to_comment. Versions from 6.1.7 to 7.1.2 is tested and supported. Warning from JIRA it is only based on some xml file in plugin source where not added 7.1.2 yet.
AmandaA
June 4, 2013
<label style="float: left; display: block; left: -140px; line-height: 1; margin-right: -130px; padding-top: 4px; position: relative; width: 130px; text-align: right; word-wrap: break-word; color: #333333; font-family: arial, tahoma, verdana, sans-serif; font-size: 13px; font-style: normal; font-variant: normal; font-weight: normal; letter-spacing: normal; orphans: auto; text-indent: 0px; text-transform: none; white-space: normal; widows: auto; word-spacing: 0px; -webkit-text-stroke-width: 0px; background-color: #ffffff;" for="comment">Work Descriptio</label>
Because when my staff enter worklog, they also enter some comment on the task. I will review the workflow.
Christian Czaia [Decadis AG]
June 3, 2013
Why would you want to do that? I mean you would mess up your comment section. That's why you have an extra tab for worklogs I guess..
