I have a project I am working for a Publication group. The pub group wants to include a group of printers with-in a Sub-task. It was not a problem because I initially was going to add a drop down select that would allow them to choose the printer they wanted to use. Now to was want to be able tp pre-populate other fields based on the printer they choose from the printer drop down select field.
Is it possible to create a custom form that will pop-up from within a sub-task that will allow for the type of action described above?
No, not out of the box. If you are doing custom-development or have a scripting plugin, then you could make it happen.
Register now
