Is it possible to define different Priorities and Resolutions for different Projects in JIRA?
Jeannette Lamb
these 2 attributes have default values but don't have schemes that can be associated with different projects. How can I have one set of Priorities and Resolutions in one project and different Priorities and Resolutions in another project?
Guillermo _DEISER_
Hello Shampa;
We developed a plugin to meet this requirement. Profields can achieve what you want and many other needs. We have just released Profields version 2.0 you can see our landing wiht the most relevant features (all versions). With profields you can create attributes associated with JIRA projects (priority, complexity, customer, technology, whatever). Then, you can use one of the gadgets we include and sort the project list by one of these attributes (i.e. Complexity).
http://www.deiser.com/subject/landing/profields/
Of course if you try it, you can also send us your feedback and your specific requirements to:
http://www.madeira20.com you can sign up and create issues with your questions.
With Profields 2.0 now it's also possible to execute JQL queries using the attributes created with the plugin. Although the JQL box works only with issues, you can combine the filter with some gadgets of JIRA.
Cheers!!
Natalie Hobson
November 30, 2012
You cannot apply context to any default field in JIRA, only to custom fields. For Priorities, you could add new custom field(s) (my studio uses a "Severity" select list and we apply different context as needed) and use that instead. For Resolutions, however, there's not really an alternative to that. You can edit the Resolutions, and perhaps give the options prefixes or suffixes so that users know when to select them, or you might try adding an html message on the transition screen used when users are selecting the Resolution, and provide them with instructions on which Resolution they should choose at that point.
