Yes You can change it.
go to this location : C:\Program Files\Atlassian\JIRA\atlassian-jira\WEB-INF\classes\com\atlassian\jira\web\action\JiraWebActionSupport.properties
Edit in that file.
issue.field.summary = Summary
replace by
issue.field.summary = Title
It work definitately
Hi Prashant
I want these changes only for a specific issue type i.e a BUG. When ever i create an issue with an issue type of bug, I want an auto-populated text like "this is a bug" to show up on the summary filed.
Thank you
Luvo
You'll need to inject some (horrid) javascript to do that.
I would not recommend defaulting a summary, unless you really do want a vast swathe of your issues to all look indistinguishable most of the time. The summary is there, empty and mandatory, for a very good reason. In the handful of places where I've seen this done, it causes problems with users complaining that the information in issues is rubbish, and we always remove it.
Hi @Luvo,
as Prashant is said u can go to that location and u can find that properties file in JIra Installation directory.
Yes U can edit the JIRA built in fields.
I want to customize Jira default fields names. For e.g I want to replace "Issue" with "Task" everywhere in Jira. I am able to replace most of it by editing "WEB-INF\classes\com\atlassian\jira\web\action\JiraWebActionSupport.properties" file. But still there are some places where it is not changing. For e.g when we click on "Issues" tab on home page there is a option "Import Issues from CSV".
Please help me where to change it?
Zeeshan
