Is it possible to filter jql results by Month?
Casey Harford
Right now, I have a JQL query like this:
project = "Customer Experience" AND status was Reviewing after "2013/01/01" AND status was Reviewing before "2013/02/01"
Instead of using "before" and "after", is it possible to just specify a given month, maybe by name(ie. January), instead of these date ranges?
34 votes
dnhoang
June 7, 2016
There is one way you can filter as the last month or the last two month etc...
Ex:
the last month: created > startOfMonth(0) ORDER BY created DESC ,
last 2 month: created > startOfMonth(-1) ORDER BY created DESC.
Similar for startOfDay(), startOfWeek() and startOfYear()
Nick Wade
These are excellent. Thanks!
Marek Vejrosta September 17, 2018
Thanks!!!!
Surfaraz T December 14, 2018
Hi @dnhoang,
Can u please tell how this filter works?
Ingenieria
February 15, 2019
Thanks !
Zarko Ajdinovic
February 7, 2020
Actually, startOfMonth(0) will list items from the CURRENT month,
where startOfMonth(-1) will list for the last month, etc...
Like • Jason Fitzgerald likes this
Romel
updated >= startOfMonth(-1)AND updated <= endOfMonth(-1) should give you all the issues updated in the last month. change the fields according to your business need.
Like • 2 people like this
Rob Horan
August 12, 2020
It would be great if Atlassian could build new easy JQL for full month searches.  I'm all in on simplifying the user experience without loss of functionality.  No reason we couldn't keep the existing functions AND new ones.
It would be helpful to have a detailed, real-world example guide.
Like • Anwar likes this
Rob Horan
October 2, 2015
I'm going to get a rep for being the cranky old man on the block, but it seems absurd that we can't simply specify a month and year as search critera.  All issues created in September 2015.  Bam!
This is a serious issue for me, as I just found that my monthly reports have been omitting issues created on the last day of the month when using JQL like this:
created >= 2015-09-01 AND created <= 2015-09-30
If you create a Basic search between two dates and then convert it to JQL you get that format.
This is a serious bug.
Matt Hurst-Smith
March 8, 2016
Not sure if this is still relevant to you, but if you use "2015-09-30 23:59" instead of just the date, this will return all issues created right up until 11:59pm (in whichever Time Zone your JIRA is set to) on that date.
Unless an issue is created during that final minute, you should catch everything. Not ideal, as it does leave room for error with that final unaccountable minute, but should be enough of a workaround.
NB: you'll need to use the speech marks around the date and time
Rob Horan
March 8, 2016
Its pretty ridiculous.  Adding an end date should include the entire day by definition.   But thank you!
Matt Hurst-Smith
March 8, 2016
Yeah it's pretty mental, I think it's something to do with the fact that JIRA assumes the day to end at midday or something.
Rob Horan
March 8, 2016
That would make more sense.  Nope.  Its exactly midnight at the start of the end date, effectively removing the end date from the query entirely.
dm
February 5, 2018
You can achieve this by searching for all dates greater than 1st Sept and less than 1st October.
Nick Wade
This is the correct answer from @dm, even with the <= implying something else.
Sergey Maximov
February 24, 2020
Instead of 'created >= 2015-09-01 AND created <= 2015-09-30'
you can do 'created >= 2015-09-01 AND created < 2015-10-01'
Like • tomy.fung likes this
Bhushan Nagaraj
May 2, 2013
JQL allows you to use a data like 2013/01/01
or
the format 30d (30 days)
What you are looking for is not possible in JQL.
Casey Harford
Not the answer I was looking for, but kind of figured this was going to be the case. Thanks for confirming.
Arun Singh July 10, 2019
Can anyone please help me with a filter to search items moved to a specific status after 12:00 noon of every alternate wednesday?
Bob Davis July 18, 2019
Export your filter results to Excel. Split the date column by spaces. use =TEXT(A1,"DDDD") to get day of week. Filter results to just Wednesday.
