Is it possible to include a custom User Property in Tempo exports?
Brian Spence
May 18, 2015
I am adding a user property to associate JIRA users to associate IDs used in HR systems.  Can I include this field when exporting timesheets from Tempo?
I see where I can specify the User Property to be used by Tempo, but it is not included by default in the timesheet exports, and cannot find a way to add it to the export.
Susanne Götz [Tempo]
May 18, 2015
HI Brian,
the User Properties can not be added to the Excel export, but you can retrieve this data by using the XML export.
Please take a look at https://tempoplugin.jira.com/wiki/display/TEMPO0712/Tempo+Servlet+Manual for more information about the XML export. To retrieve all User Properties (if a user has other Properties than the Staff ID), you need to add the "addUserDetails=true" parameter to the URL.
Susanne
Josh Kronick January 31, 2019
Susanne --
i am trying to do the same exact thing that this user's question states... add user properties to a report export in Tempo for JIRA Cloud.
does the servlet work with Tempo for JIRA Cloud?
please help!
Susanne Götz _Tempo_
February 1, 2019
Hi @Josh Kronick,
There is a version of the Tempo Servlet for Cloud, but it is not possible to retrieve the Staff ID with it. This functionality is not avaiable on Cloud.
Please take a look at https://tempo-io.github.io/tempo-mtm-docs/ for information about the Tempo Servlet for Cloud.
Susanne
Read the story
