When I type BioPortal and I just want the second P to be bold, it is shown as Bio*P*ortal.
BioPortal
hi @Applicatiebeheer Naturalis,
Have you tried adding the word like below?
Bio*P*ortal
It will looks like below.
hope this helps 😊
Thank you Alana, when I do this it first looks ok, but after saving it becomes Bio*P*ortal
What happens when you just select the P and click Bold button?
Thank you Alana, your first suggestion I tried already but didn't work, the second works:)
Glad it worked
this is a followup,
I got to know that currently, Jira does not support partial formatting, There is an existing feature request asking for this functionality JRASERVER-65414, you may vote the issue and it will be addressed in accordance with New Features Policy.
suggested second method works fine since it is the current workaround available
partial{color}*word*{color}
It should show as BioPortal, which works fine here, but not in our Jira environment. Does somebody know how to fix this?
Save your spot
