Is it possible to move the Log Work menu item from the More Actions Menu to Button?
Eric Blair
We'd like to take the Log Work menu item from the More Actions menu and make it into a Button. This would make it more visible and readily accessible so people don't easily forget to enter their time.
Jobin Kuruvilla [Adaptavist]
November 17, 2011
There is a web section for 'Log Work' in system-issueoperations-plugin.xml under WEB-INF/classes folder. You can change the weight property of it to '5' and the Log Work will appear on the top!
<web-section key="operations-work" name="Ops Bar Operations Work Section" location="opsbar-operations" i18n-name-key="webfragments.view.issue.opsbar.operations.work" weight="5"/>
You should restart JIRA for this to be effective.
Eric Blair
Thank you Jobin! by "on the top" do you mean that is will just appear at the top of the menu, but not as a button, correct?
November 17, 2011
If you do this, it will appear as a button because the first few items in the menu will appear as a button. You can however change how many items should appear as buttons or change the ordering of elements so that the 'Log Work' doesn't appear in that list.
In short, play with the ordering and you can add it to the top.
Eric Blair
Thanks! Ok, one last question. Is this configurable by Project?
November 17, 2011
No it's not. It is actually a workaround ;) You can add a new operation for the project and push it up but that is a new plugin!
Frank Schönheit October 17, 2013
@Jobin:
How's that done, please? I managed to move that "Log Work" item (the whole web-section, effectively, consisting of one item) to the top, so it appears as button. But then the item which previously appeared as button ("Assign") moved to the drop-down menu, which isn't really the desired result.
October 18, 2013
Frank Schönheit October 21, 2013
Frank, check this out: https://answers.atlassian.com/questions/142540/how-to-change-the-workflow-buttons-on-the-issue-screen
Ah! Abstracting from "transitions" to "operations" in that article indeed gives the solution to that. Thanks a lot!
Tal Ben Basat
January 4, 2018
@Jobin Kuruvilla [Adaptavist]
is it possible in the cloud version?
January 4, 2018
@Tal Ben BasatNo, its not.
Ashley Mendes
October 19, 2016
I know it's been asked before, but it's been a while since anyone was on this thread.  Has anyone found a way to make "Log Work" its own button for JIRA On Demand?
Andrej Kvasnica March 9, 2015
In JIRA-6.3 you have to increase the amount of displayed operations adding
ops.bar.group.size.opsbar-operations=2
to data/jira-config.properties file, and change weight from 20 to 7 in section
<web-section key="operations-work" name="Ops Bar Operations Work Section" location="opsbar-operations" i18n-name-key="webfragments.view.issue.opsbar.operations.work" weight="7"/>
within app/atlassian-jira/WEB-INF/classes/system-issueoperations-plugin.xml file.
After JIRA restart you'll see "log work" as button next to "assign".
Adam Austin
December 1, 2015
This worked nicely for us using JIRA 7, however, the Log Work REPLACED the Assign button in the standard view issue screen, which is fine for us, as we do not need to see them both. Note that we had to create the jira-config/properties file, in the /var/atlassian/application-data/jira/data/ directory.
Marcus Culver
January 28, 2014
Does anyone know if there is something like this for on-demand users or if Atlassian would happily conduct this change to a customers instance?
Frank Schönheit October 16, 2013
@Jobin:
