Is it possible to restrict the issues from another project to my project
M Sunil Kumar
I want to restrict the issues to import to my project. If users are trying to move issues from other project to my project that action should not perform.
Thanks & Regards,
Sunil Kumar M.
5 votes
Ash Yadav
October 28, 2024
Hi @M Sunil Kumar
Users cannot move issues into your project if they aren't granted the "Create issues" permission within your project.
I would start by reviewing your permission scheme and adjust accordingly.
See: https://confluence.atlassian.com/servicemanagementserver/moving-an-issue-939937218.html
KR,
Ash
M Sunil Kumar
Hi @Ash Yadav ,
Thanks for the response!
Is there a way to restrict using automation rule in that project. If have can you suggest rule please.
Kind Regards,
Sunil Kumar M.
M Sunil Kumar
Hi @Ash Yadav ,
Got the solution, Thanks for the response
Stefan Stadler
October 28, 2024
@M Sunil Kumar Would it also be possible to share so that others can use this as well?
I would be interested in how to prevent moving issues.
SERVER
