Is it possible to restrict work log "Remaining Estimate" options?
Yves Martin
September 13, 2018
 Hello
I am looking for a way to limit available radio options of "Remaining Estimate" in "Log work" issue form, typically only leave "Set to" option and hide/disable others. And if even possible, configured on a per-project basis.
Is there a way to do it, for instance with Adaptavist Scripter Runner plugin my instance already runs?
Tarun Sapra
September 13, 2018
Hello @Yves Martin
Possible duplicate here
https://community.atlassian.com/t5/Jira-questions/Customize-exclude-fields-from-the-Log-Work-dialog-box/qaq-p/11186
You would need to change the vm template of the underlying screen in order to customize it
and if you are using tempo
https://community.atlassian.com/t5/Jira-questions/Tempo-Log-work-screen/qaq-p/239289
Yves Martin
September 13, 2018
Correct. Thanks for pointing that question... my searches have not lead me there.
