×Good Day
I am trying to help a colleague create a report for Work Logged, but he would like to see the amount of time spent working on a task per user that had logged work.
Please any advice would be great.
You can have a look at the time tracking addons (some are free, for some you have to pay)
Yes, there is even a separate category for time tracking:
Or, if you your requirements are not too extensive, you could start with the built-in report. Go to your Jira project / select Reports / scroll down and select Time Tracking Report
you can have a look at our app Worklog History which shows hours logged directly on the issue.
If you need more functionalities, please also check Worklog History PRO and its special viewer.
Lime Trees Support Team
