Is it possible to set automation for the first comment only?
Liam Maeder
Good day
I am trying to set up automation that updates a custom field, but only on the first comment.
Any help would be much appreciated.
fran garcia gomera
October 1, 2019
scriptrunner provides a JQL function to get issues with a given number of comments
issuefunction in hasComments()
https://scriptrunner.adaptavist.com/latest/jira/jql-functions.html#_hascomments
With this you can set a condition in automation (in case you are using it)
also it could be possible to access the number of comments via smart values for automation.
something like {{fields.comments.size}} and use it as a condition comparing the value with 0 (not checked, just guessing)
Sebastian Krzewiński
October 1, 2019
Hi @Liam Maeder
What do you use to do this? Automation for JIRA add-on perhaps?
Seba
Liam Maeder
Hi @Sebastian Krzewiński
I am trying to use JIRA Automation.
October 4, 2019
Hi
Did you try {{issue.comments.size}}?
More info you can find here: https://docs.automationforjira.com/reference/smart-values.html#issue-comments
Below example how you can use it:
Seba
