Is it possible to setup issue field 'layout' schemes like screen schemes?
Nord Carverson January 29, 2019 edited
As it stands I seem to have to add fields to the layout for each project I create because Jira doesn't include those I want from the screen scheme I've assigned to it.
(And why for me would 'story points' appear when that field isn't in the screen that the layout is derived from?)
Alexey Matveev
January 29, 2019
Field layout has nothing to do with visibility. In screens you set fields, which must be visible. In a field layout you define some options for field like required, hidden, renderer. In field layouts all fields are present.
Or you are on Jira Cloud and you mean Issue Layout?
Nord Carverson January 30, 2019
I am on jira cloud yes - and it's the issue layout I'm referring to.
Thomas Dittscher July 16, 2019
Hi.
Was there a solution to this question? I'm struggling at the same point.
I would like to have the same issue layout in every newly created project, but I don't know how to do it.
Best
Thomas
