The docs on Managing multiple directories describe this sample scenario:
If that's true, why can I perform the following actions?
With this directory order:
I select 'JIRA Internal Directory':
And the user is created in JIRA Internal Directory:
So the question is: Why am I able to create a user in JIRA Internal Directory?
My guess is that the configuration of the LDAP directory might not be read/write, but I am unsure on how to check that, even after having had a quick look at the 'Directory Configuration Summary' page.
Any ideas?
I believe that document might be using an outdated example. At one time in older Jira versions I believe this was true. However in modern Jira Server versions it certainly does appear that you can create new users in the directory of your choice.
As such I have created a ticket for our documentation team to update these pages accordingly. You can track that progress over in https://jira.atlassian.com/browse/JRASERVER-66520
Thanks for bringing this error to our attention.
Andy
The ACP-100 prep materials have a video with the same sample scenario and expected answer.
I've voted and started watching JRASERVER-66520. Thanks for having created it, Andy!
@Ignacio Pulgar I have also notified our Certification team in regards to the certification materials on this topic. I am sure they will want to investigate this further to understand if this might require an update to the training materials and/or testing aspects.
Awesome!
Looking forward to knowing what answer will be considered to be the correct one in the exam.
Thanks again, Andy!
@Andy Heinzer Just to help the Certification Team finding the materials that need to be reviewed:
4th Video: "JIRA Admin Knows Best"
Time 8:02 > Sample question states 'The ability to add new users to the JIRA Internal Directory' will be impacted by changing the LDAP directory to the first position.
12th Video: "Permissions, User Directories, and Workflows"
Time 1:10 > "We also need to know that where users are created depends on the order of the user directories."
@Andy Heinzer By the way, I've located some more controversial info in the prep materials. What would it be the best method for sending potential errata to the Certification Team?
Save your spot
