Is possible to use multi-line text fields with Nfeed plugin?
Vidic Florjan
June 15, 2015
Is possible to use multi-line text fields to display longer text strings with JIRA Nfeed plugin?
Florjan
Vidic Florjan
June 28, 2015
It is currently not possible to use multi-line text fields to display longer text strings with JIRA Nfeed plugin.
Abdul
June 15, 2015
Hi Florjan,
Currently only the below display mode is supported by nFeed :
  • Autocomplete – To have an autocomplete text box with plenty of options.
  • Query results picker – To select the data displayed in a table in a raw format.
  • Read-only – To display data in JIRA issue edit screen with no action on it from the user.
  • Select list – To display 1 to 9 select lists in the same row to lead the user to filter and finally select the data.
Can you please provide me of example of your usecase ?
Vidic Florjan
June 16, 2015
Hi!
The latest request of our customers is to display service description of the previously selected service (in related nfeed custom field) in a box like for standard Description field (with more than one line!).
They need description of the service to check if their service selection is ok.
As a workaround I see connection of nfeed customfield and standard milti-line text field but I don't know how to connect them and how to fill this standard field automatically in opened form (e.g. for other fields we use behaviours plugin - but it doesn't work with nfeed fields). Maybe with REST somehow? Do you know how to achieve this?
Thank you and regards,
Florjan
I also created support ticket in Nfeed project (NFEED-1219).
Vidic Florjan
June 16, 2015
Additional information: We use Read-only mode for field with service description and autocomplete mode for field with list of services.
Register here ⬇️
