Is there a loop function in JQL?
Dr. Alexander Loitsch October 1, 2019
I have got the following challenge, but do not know if i can do the JQL query in JIRA:
Target: I want to find all EPICS with the text string "Messwerte" in it and then I want to show all USER STORYS assigned to this EPICS. I know, can do this "manualy" with this two JQL-Statements:
1) type=EPIC AND text ~Messwerte
After this, I put the results  (AGENT-xxxx, AGENT-yyyy...e.g.) in the second JQL-query:
2) type=Story and "Epic Link" in (AGENT-3247,AGENT-6091,AGENT-7694,AGENT-9049,AGENT-6458,AGENT-4105,AGENT-1937)
But is there a possibility to do this in one JQL query? In UNIX shell scripts I would build an array with the result from 1) and then I would build a loop over it with 2).
But how can I do this in JQL?
Cheers
Alexander.
Ilya Turov
October 1, 2019
Hello, it's not possible to do out of the box, but different plugins have different kind of additional JQL functions that can get the job done.
For example, with scriptrunner you can do it like this:
issueFunction in issuesInEpics("text ~Messwerte")
Hello Ilya,
thx a lot for the information :)
Cheers
Alexander
Learn more
