  • Community
  • Q&A
  • Jira
  • Questions
  • Is there a plugin available for MS Excel that works with in-premises hosted Jira (not in cloud)?
L.C.
June 26, 2024
The following plugin is available for Jira Cloud:
Jira Cloud for Excel
https://pages.store.office.com/addinsinstallpage.aspx?assetid=WA200000556&rs=en-US&correlationId=ee95d163-b36e-bee8-2910-db56dd718629
Does it also work for in-premises hosted versions of Jira? If it does not, is there an equivalent that works for these?
My company runs Jira v9.12.5
Thanks in advance,
Best Regards
L.C.
2 accepted
Hannes Obweger - JXL for Jira
Hi @L.C.
welcome to the community!
while it may follow a slightly different approach than what you have in mind, you may want to have a look at the app that my team and I are working on, JXL for Jira.
JXL is a full-fledged spreadsheet/table view for your issues that allows viewing, inline-editing, sorting, and filtering by all your issue fields, much like you’d do in e.g. Excel or Google Sheets. All this happens directly in Jira, on live Jira data. This is how it looks in action:
For more sophisticated use cases, JXL also comes with a range of advanced features, including support for (configurable) issue hierarchies, issue grouping by any issue field(s), sum-ups, or conditional formatting. With these, you can create virtually any issue view or report in just a couple of clicks.
Best,
Hannes
Manoj Gangwar
Hi @L.C. ,
Welcome to the Atlassian Community!!
Please refer to the below plugin -
https://marketplace.atlassian.com/apps/1222961/excel-365-connector-for-jira?tab=overview&hosting=datacenter
Glen Cochrane
When we were on-prem we would run our query/filter then Export to CSV and save as .xlsx
It is an option, although a few extra clicks; not necessarily ideal depending on usage/process you are doing.
Glen
MobilityStream
June 26, 2024
Hi @L.C. ,
You can try our Excel Integration add-on. It works with Jira Datacenter/Server & Cloud and Excel Desktop & 365. It supports direct downloads of Excel files or data can be directly exported to OneDrive/O365. Exports can be one-time, scheduled, or real-time You can also export much richer data to create more sophisticated reports (Assets, Changelogs, Projects, Sprints, Users, etc.). Everything directly controlled within Jira. Give it a try.
The Mobility Team
