  • Community
  • Products
  • Jira
  • Questions
  • Is there a tool or method to export a project from one instance of Jira (Test) and import the project into another Jira instance (Production)?
Stephen Stewart
December 6, 2011
I have a Jira instance used for testing that we create Jira projects in to verify with business customers. When the business customers are satisfied with the project in our testing Jira, we move the project into the Production jira instance for our business customers to use on a regular basis. Is there some tool or feature that allows you to export a Jira project from one instance and import it into another Jira instance? Is it possible to automate this process so that we can replicate between two environments (Test <-> Prod)? I came across a tool called "Swizzle" that appeared to do what I want, but it seems to be very loosely supported and old.
Any help you could provide would be greatly appreciated!
38 votes
aarnetadmin
You would still need to do some manual mappings in case your new project uses configuration elements (issue types, workflows, etc.) not present in the target instance (Production), but once you set it up, the issues are copied with the entire history.
This is still way too clunky and brittle for enterprise use; there's far too much room for user error.
Jira really needs to get proper test, qa and production instance management rolled into the core product. Simple things like being able to detect the base url has changed between instances, or a way to do so that isn't part of some fifteen step process.
Deleted user July 31, 2012
This is also what we need. The problem is that we are moving one big project from one server to another with many custom schemes/fields/workflows and custom issue types and creating all this manually would take too much time. We are considering a database dump / restore but that would also copy the other projects from our server and we don't want that.
Like # people like this
Harry Chan
September 10, 2012
There shouldn't even be a need for base URL. That's a major pain.
David Feig April 16, 2014
I strongly agree with rob.kearey.
22 votes
Wojciech Seliga
December 6, 2011
You can export your data from Test JIRA to XML (Administration | Export & Import | Backup System) and then you can import just a selected project using Project Import functionality.
The other method could be exporting given project (as a result of Search) to Excel, then to CSV file, then back to JIRA using CSV import. But then you will loose the history and the mapping would be usually more cumbersome as CSV does not keep any field metadata.
Tina McAninch
February 6, 2014
When using the export to XML/Project Import option, what problems, if any, are likely if the source instance is Jira 5 and the target instance is Jira 6?
Sverre Moe
I would like to know a respons to this question myself. I am faced with importing a Jira 5.0 project into a different Jira 6.x instance.
José Marañón [Awnaba Software S.L.]
April 9, 2014
Follow the advice at https://confluence.atlassian.com/display/JIRA/Restoring+a+Project+from+Backup. There is a section called "JIRA versions do not match" that explains what to do when versions for source and target instances are not the same.
If you combine that with the use of Project Configurator plugin, you save yourself all problems related to mapping the project configuration from the source to the target instance. (I am a developer of that plugin, so maybe I am a bit biased here ;-)
Like Mahesh Kallepalli likes this
Eric Tucker
October 1, 2015
"then you can import just a selected project using Project Import functionality." Where is this? I see no such option. There's still an open issue with JIRA for adding single project import. Do you know something we don't? Or have a plugin installed that you didn't mention?
October 1, 2015
@Eric, I think Wojciech meant the JIRA Project Import Tool, as described in https://confluence.atlassian.com/display/JIRA/Restoring+a+Project+from+Backup. This functionality is part of standard JIRA. Bear in mind that the "manual mappings in case your new project uses configuration elements" can be automated with the plugin Project Configurator (https://marketplace.atlassian.com/plugins/com.awnaba.projectconfigurator.projectconfigurator). The whole process for moving a project without any manual task is described at https://awnaba.atlassian.net/wiki/display/PCP/Moving+a+project+to+another+instance
Akshay K.V. January 25, 2018
@José Marañón [Awnaba Software S.L.]Project Configurator Plugin supported in Jira Data Center 7.3.8 ? We are planning to migrate a number of projects from Standalone instance to Data Center.
January 25, 2018
Hi Akshay,
Yes. It is supported on that version of Data Center Jira.
Cheers!
Thanks @José Marañón [Awnaba Software S.L.]. We will give it a try and come back with the results.
19 votes
March 3, 2013
There is a new plugin in Atlassian Marketplace called "Project Configurator" designed to transfer the configuration of a project from one instance of JIRA to another. It only transfers configuration (custom fields, workflows, schemes, permissions,...) but not issues or attachments. The idea behind the plugin is to cover the use case of a development instance where changes are made, and a production instance where those changes should be applied, once they have been tested.
(Disclaimer: I am involved in the development of this plugin)
aarnetadmin
This actually works very well; it's a shame it has to be provided by a third party rather than being core functionality.
Like Kyle_Semon likes this
August 16, 2016
Version 2.0 of Project Configurator for JIRA, released a few days ago, goes one step beyond and now offers an integrated way to export or import a complete project (that is, not only its configuration, but also issues and attachments)
Like FaithNassiwa likes this
Sri October 3, 2016
Does it import the Agile Boards in JIRA 6.4.x ?
October 3, 2016
@Srikanth Not yet. That feature will be released next November.
Piyush_Annadate October 4, 2016
that's great but what about the SPRINTS ? XML/CSV export does not cover the Sprint details !!!
Still - what about SPRINT - anyone to help about this?
October 4, 2016
Starting with JIRA 7.0 sprint data is recovered when importing project data as explained in this page, in the section called "Project import restrictions". As Project Configurator uses this part of JIRA internally, this should solve the import of sprints.
I know this will not make users of JIRA 6 & JIRA Agile quite happy, but at least it is a starting point.
David Skreiner
October 4, 2016
Cool! I think you're the only plugin salesman on here I've ever seen stating that they work for that plugin. Usually, they just answer "you need my plugin, here's the Marketplace link" even if there's other workarounds. laugh
venkatasai_pulluri November 17, 2017
We have two different versions of instances.
old 6.2.7 standalone version
new 7.3 datacenter model
Do you think this plugin can help to migrate all configurations and issues ?
Just want to make sure before we try it. We dont have test env for old JIRA
Nic Brough -Adaptavist-
November 17, 2017
It will, but you may need to upgrade 6.2 to 7.3 to move everything cleanly.  (Standalone and Data Centre differences won't affect this process)
We will not be able to upgrade the old one. That is the reason i want to find out if this plugin works without any compatibility issues.
What could be possible issues ?
January 25, 2018
You can use an intermediate instance, as explained here, so you would not have to upgrade the original source instance.
Cheers!
Loli_ola January 23, 2020
will this plugin work for 7.10 to 8.6 Jira server?
8 votes
Arun_Thundyill_Saseendran
April 3, 2015
Now a new tool called Configration Manager for JIRA (https://marketplace.atlassian.com/plugins/com.botronsoft.jira.configurationmanager) is available. It does pretty good in copying configurations from one JIRA instance to the other.
For data transfer, export as Excel and import as CSV or XML back up and import will be fine.
For attachment transfer, create a file by querying all weblinks and issues key. The you can run a small REST app to pull the attachment from the source instance and post it to the target.
However, it is a real shame that JIRA does not have the options for these out of the box.
Brijesh Jain
April 9, 2015
Thanks for that link. Unfortunately it only works for JIRA 6.0 and above. But good to know it exists now..
AntonioP April 10, 2015
Yeah, I Agree. This kind of functionality is very useful and should be out-of-the-box. But I would rather use for this, Project Configurator (https://marketplace.atlassian.com/plugins/com.awnaba.projectconfigurator.projectconfigurator). It is more popular, supports filters and dashboards and has a far better price. It even has versions for JIRA 5.X! We've being using it for two years, with a fantastic support. It's very reliable!
Karla Bernal
what if i don't have a budget to buy it? is there any way to do it by free?
Ligia Merciu
July 10, 2016
Hi guys,
If the scope is to move a project configuration, without any issue, from one JIRA instance (i.e. a test environment) to another JIRA instance (i.e. production environment) the most useful tool is https://marketplace.atlassian.com/plugins/com.keplerrominfo.jira.plugins.kiwi/server/overview
If you already are somehow familiar to SIL (Simple Issue Language provided by https://marketplace.atlassian.com/plugins/com.keplerrominfo.jira.plugins.jjupin/server/overview) you can also use the Pre-Import and Post-Import files feature to create the project on the destination instance and to associate it with its schemes. However, the schemes have to be manually configured before, if they do not exist on the destination instance. All the rest the project implies (workflows - doesn't matter how complicated they are, screens, customfields, customfields contexts - that meeans all the entities associated with a workflow) KIWI is able to handle successfuly.
Note that KIWI does not export/import the issues between instances.
Hope this help! smile
Like Charles Johnson likes this
3 votes
Markus Egg
February 14, 2012
Is there no kind of "Save/Load" functionality, with which I can save a complete project in a file and load this project from that file later on (without manual mapping or editing)?
David Skreiner
October 4, 2016
It's possible to export workflows ... but if your JIRA instance A has a different setup than JIRA instance B, the workflow will be utterly unusable because it'll use wrong statuses.
It's possible to create a workflow on a JIRA A, export it, and import it to JIRA B, if your two JIRA servers use the exact same screens and statuses. (e.g. if you have  a Staging JIRA that's a copy of your live server).
Justin Alex Paramanandan
December 14, 2012
I actually worked on a small project to perform such a mammoth task before. You can attempt to view the steps here: Migrating Certain Projects from JIRA.
Give this a shot, and see whether it fits your requirements.
Richard Cross
Dead link
Karla Bernal
hi, the link is not available anymore :(
diego bowen November 29, 2012
What about all the attachments associated with the projects using the XML project export/import tool. Our attachments are on the filesystem and are not being copied over. Thanks
C Olson
August 6, 2013
Yes - I have the same question about extracting attachments.
Were you able to figure this out? If so, please advise
thanks
Karla Bernal
https://confluence.atlassian.com/display/JIRA/Migrating+JIRA+to+Another+Server backup attachments and index directories (if located outside jira home directory)
Renjith Pillai
September 10, 2012
This is tricky if you have customfields, worflows etc getting created for each project. Could you please explain why the tests itself happen on the production instance (may be with limited access) and make it with appropriate permissions once the testing is over?
You can also just copy a project within the instance easily with Jamie's script runner so that the customers can start with a clean instance once they want to switch over to production. So start with a project key like TST-<<based on customer>> and then once testing is over, copy project to the actual project key.
Once done you can delete the old project.
https://studio.plugins.atlassian.com/wiki/display/GRV/Built-In+Scripts#Built-InScripts-CopyProject
Gregory Kneller
January 23, 2020
It is hard for service desk projects and data from some add-on. You would rather create a TEST project in production instance, then in a separate test instance.
Martin Hošek September 25, 2018
Hi Stephen,
the best option would be a synchronisation app from Atlassian marketplace.
I personally use the J2J Issue Sync app which works great for me:
https://marketplace.atlassian.com/apps/1215323/j2j-issue-sync?hosting=server&tab=overview
It can synchronise projects, issues and fields between two or even more Jira instances. You can try it free before buy so you can test if it meets your requirements.
Martin
K. Yamamoto
March 6, 2017
For cloud instance, try the procedure on How to merge two different JIRA Cloud applications together.
In a nutshell, merge projects on JIRA Server and put the merged projects back to Cloud.
Andriy Yakovlev [Atlassian]
January 12, 2016
siddha1990
January 21, 2015
This add on is not available on cloud..Any suggestions?
January 21, 2015
If you are moving your project from the Cloud, you can always make a backup and restore it into a Server instance. Then you export from this instance. If you want to merge Cloud instances, copy them to server instances, merge there and upload the result to the Cloud. This process would be good also for moving projects from Server to Cloud.
See process explained in the URL mentioned by @Kenta Yamamoto below and in another comment above this one.
K. Yamamoto
March 6, 2017
March 6, 2017
Hi  @Kenta Yamamoto,
Yes, your comment is very accurate and actually we have references of customers working with projects from JIRA Cloud with the process you outlined, I will update my previous comment.
Gregory Kneller
October 5, 2012
Project Import Tool is the only thing provided by Altassian. You need to make sure that all custome fields, issue types, issue security levels, resolutions and permissions that you have in the source instance, exist in the target (production as you say). If you use workflows, export them before. If the workflows use screens, you need to patch XML files and change screen ids. I have moved about 40 projects from one very messy instance to another one, so I am pretty sure that it is possible in general case. But it requires sorting out many things, that is sometimes possible only through direct changes in the databases.
Gregory Kneller
September 10, 2012
If you use MySQL or Oracle database for your JIRA, you may create SQL patches to apply over production database, that will create the project with workflows and security schemes. It requires however good knowledge of JIRA database and SQL, and attention to the values of primary keys. Alternatively you may pay with Jelly scripting, but it has very limited functionality.
Al Sko June 8, 2012
if you can create the required project, users ,etc manually, then you can use Task Adapter to transfer tasks between two Jira instances.
