Is there a trigger for when a pull request has been approved?
Peter Trang
Is there a trigger I can use for the workflow to transition issues when a pull request has been approved? There are triggers for open, reopen, PR created, declined, but no approved.
2 accepted
Deleted user March 30, 2018
This is correct: there are no triggers for Pull request approved.
The complete list of triggers is available in the documentation in the section Understanding triggers.
Peter Trang
I can't find where to put in a request for a "Pull Request Approved" trigger.
@Peter Trangyou can submit a suggestion to the product team issue tracker:
John Huh
February 21, 2019
I second this feature request.
Adam Wride
March 27, 2019
I have added this feature request here: https://jira.atlassian.com/browse/JRACLOUD-71798
Please vote/watch/comment.
Jobin Kuruvilla [Adaptavist]
March 31, 2018
Until Atlassian adds triggers for approvals, you can use webhooks. See https://confluence.atlassian.com/bitbucketserver/managing-webhooks-in-bitbucket-server-938025878.html for more details.
Make a transition call on the PR Approved event.
Ian Mackay
August 2, 2018
Can you detail how one would do this? I have the same issue and would like to use webhooks if that's possible, but I don't know how to get Jira to listen appropriately.
Like • Ahsan likes this
August 2, 2018
You will need to use a valid JIRA REST API url to perform your operation. Check out https://docs.atlassian.com/software/jira/docs/api/REST/7.11.0/ for available REST end points  in JIRA
Anonymous
November 21, 2019
buy for expensive and make it yourself :)
Like • 2 people like this
Ahsan February 12, 2020
@Jobin Kuruvilla [Adaptavist]
could you please share some example code for this ?
Learn more
