Can i add multiple(bulk) users in to a group ?
I have 100+ users i wanted to add to a group in one go?
User management > Group > Edit members (on the group you want) >
At the Add user screen click the icon :
image2015-1-28 15:5:52.png
Then select the users you need:
image2015-1-28 15:9:7.png
Hello Philippe, Unfortunately i don't find this option (Bulk Edit Group Members) on Cloud JIRA. Yes i can find this on local installed version..
You need to have browse users permission to see this option.
I am a site admin on our instance and I don’t see any options to do this either. Why is it not possible to use groups defined in Google to map users to groups in the Jira instance?
Save your spot
