Is there a way to create a multi-text input field or a multi-URL field?
Rob Horan
August 19, 2022
I am assisting a team with Jira configurations, and one requirement is to have a field for a user-defined set of URLs, and another is to have a set of user-defined lines of text.
Rather than having one giant text space, they want the ability to enter a line of text/URL and add it to the field, then add another, and another, etc., with each entry being a distinct value.
Essentially it would be a multi-value field without pre-defined values; the fields would allow for users to enter text; one field would support standard text, and another would be specifically for entering URLs that would be clickable in view mode.
Plugin solutions will work, preferably (but not necessarily) no code or low code.
Michael Simmons
September 14, 2022
Hello @Rob Horan
Unfortunately, every entry in your example would need to be a unique field in Jira. I'm sorry this is not the answer you want, but it is a limitation of Jira.
Take care,
Michael
If you accept this answer please mark as accepted. Thank you.!
Rob Horan
September 15, 2022
Thanks!  It's not so much not the answer I didn't want but the people who asked :)
I was pretty sure this wasn't possible, but I wanted to confirm.
