Is there a way to define a customfield as UNIQUE ?
Manuel Campomanes
In JIRA 5.0, can I set a customfield of type Text (<255 char) as UNIQUE ?
Sascha Ziemann
The plugin does not prevent spaces in the value. If you define a field with the regular expression "^[a-z]+$", you can add the following values: "ABC", " ABC" and "ABC ". The Add-On accepts them all as values, which differ from each other. => FAILURE
Jobin Kuruvilla [Adaptavist]
June 26, 2012
Not out of the box in JIRA. You will have to develop a new custom field type in a plugin.
Nic Brough -Adaptavist-
June 26, 2012
What you're asking for there is to block all custom fields after the addition of one single short-text field. That's really not a good idea, and not supported - the point of custom field types is that you CAN have many of them.
Jira certainly won't support that off-the-shelf, but it may be possible to create a custom field type that only allows one instance of itself.
I wouldn't bother though - if you really need to have one and only one instance of a custom field, then the most flexible, cheap, fast and effective option is "educate your administrators not to add more than one".
June 26, 2012
I thought he is asking about making the value unique and not the custom field itself! Development anyways ;)
June 26, 2012
Ahh, unique value, right. I didn't see that in the question, so if it's that, I apologise! (And still agree with your answer - reach for the development kit...)
atlassian, confluence administration certification, atlassian certified professional, confluence admin for cloud, atlassian learning, confluence training, confluence certification exam, confluence cloud admin, admin credential, atlassian certification
Become a certified Confluence admin today! 📖
Stand out as a skilled Confluence Cloud administrator. The Confluence Administration for Cloud certification proves you can configure permissions, manage site and space settings, and monitor activity—ensuring secure, effective collaboration for your team.
