×Hello, I am looking for a way to require a Comment whenever an issue is assigned. I have seen a workaround by turning off the "Global Assign" functionality and then creating new transitions that include a required field but hoping there is an easier/quicker solution that does not involve Global Settings in JIRA 5.2 or 6?
Thanks in advance for any help
~Tim
What you're doing is right. All you need to do is get the "Field Required" validator (https://marketplace.atlassian.com/plugins/com.googlecode.jira-suite-utilities). If i'm not mistaken, it does that. If not, try this (https://marketplace.atlassian.com/plugins/com.innovalog.jmwe.jira-misc-workflow-extensions).
Is there a way to do this in Jira Work Management? Team Managed?
Thanks Timothy and Udo!
Thank you for the nudge in the right direction regarding JiraSuiteUtilities...however it seems I can look for null at any field except "comment". I wil try to socialize changing the field to something else that I can modify and make this viable to make mandatory for each assign operation.
Not sure what to do with: jira.permission.assign = denied (for details see here)
It seems that this would disable comments from being shown/made and then allow me to insert my new field with the above workaround...?
~Tim
Instead of turning off Global Assign functionality you could use workflow properties on each step.
Beside that you could proceed as Timothy described,
