Is there a way to get a list of all labels being used in a single JIRA project?
DI2E Licensing
February 18, 2014
I need a concise list of all labels in use. Rather than including a label column in the issue list view and go page by page, writing them down.
I'd be happy with a SELECT query.
Karla
14 votes
Henning Tietgens
October 14, 2014
For JIRA versions, where there is no labels tab for projects, you can add a labels gadget to your dashboard and select a project within this gadget to get all labels used in a project.
Andrew Dapkiewicz
October 20, 2014
Thank you, this worked like a charm.
Matthew Kerle March 8, 2015
sorry, dumb question, how do you do that? does the labels gadget need to be installed or just configured?
Like # people like this
Ariel Allon
June 7, 2021
The above link is now to a list of gadgets.
How to add a (generic) gadget is now here: https://confluence.atlassian.com/jiracoreserver073/adding-and-customizing-gadgets-861257074.html
Henning Tietgens
February 19, 2014
If you go to the project page there is a tab for Labes where you can see all labels used in this project.
Ramon Padilla
This option is not present in JIRA v6.3.6.
Abhimanyu Gadroo November 16, 2017
Yes can't see that option anywhere. Need a quick answer on this. Please Update.
Leonard Chew
July 5, 2018
And this would be the sql select statement to list them directly from the database.
Project is the project key.
The field "customfield" is the customfield of type "label". If customfield is empty, its a "normal" label.
Occurrences is the number of occurences :-).
select p.pkey project,
l.label label,
cf.cfname customfield,
count(*) occurrences
from jiraissue ji
join project p on (ji.project = p.id)
left join label l on (ji.id = l.issue)
left join customfield cf on (l.fieldid = cf.id)
where l.label is not null
group by p.pkey, l.label, cf.cfname
order by project, label;
kondratiev
February 6, 2019
select ji.issuenum,ji.reporter,ji.creator,ji.summary,ji.created,l.label from jiraissue ji
left join label l on (ji.id = l.issue) where ji.project = 00000 order by ji.issuenum;
2019
for Jira  ~ 7.7, change 00000 to your project id
Like GI account likes this
