Is there a way to get back issues deleted issues by mistake?
mel vega
would you know if it is possible to get back some issues deleted by mistake?
melissa
3 votes
Deleted user February 25, 2016
None. Once it's deleted, it's gone gone gone.
You can restore your whole JIRA instance to a certain point in time from an XML backup (if  you are running one) but it will affect everything.
Joe Pitt
February 25, 2016
For these reasons I don't allow deleting of issues by anybody. It WILL eventually come around to bite you. I suggest a resolution code of 'Deleted', 'OBE', or 'Withdrawn By User' instead.
Sten Sundelin
February 25, 2016
We do almost the same, we only allow a very small group of 'superadmins' to delete issues. For almost all purposes, Status 'Closed' with a proper Resolution set will serve the purpose for us.
Nic Brough -Adaptavist-
February 25, 2016
A couple of places have a "bin" project which you move "deleted" issues into as well.
MattS
February 25, 2016
Yeah, the trashbin approach is painful since issues' fields may not all be visible then. I've played around with using an issue security scheme to make the issue invisible to most people.
Anyway, the way to get the lost data back is to restore a backup into a separate throwaway instance of JIRA
mel vega
Hi @Nic Brough [Adaptavist]
Thank for your answer. could you please tell where I can find this "bin" you mention ?
melissa
Sten Sundelin
February 25, 2016
Not really, your only option to completely restore them is to roll back to your latest backup before the deletion, but then you lose any recent changes.
An alternative is to install this backup on another system and copy and paste from there. You won't get all the history on the issues, but maybe this is preferable.
