I'm using JIRA 5.0 and am wondering if there is a way to limit a user's ability to create certain issue types.
Here is my example.
JIRA groups: jira-client, jira-product_owner, jira-developer, jira-qa
JIRA issue types: ticket, epic, user story, bug, enhancement, test case, technical task (sub-task)
Issue Types breakdown by role:
jira-client: ticket
jira-product_owner: ticket, epic, user story, bug, enhancement
jira-developer: epic, user story, bug, enhancement, technical task (sub-task)
jira-qa: bug, enhancement, test case
Is there a way to limit their visibility to create these issue types according to the above mapping? For instance, users in the jira-client group can only create tickets and users in the jira-qa group can only create bug, enhancement, and test case issue types.
I did notice an Issue Security Scheme which you can set on creating of an issue type which after it has been created, depending on what those scheme settings are, the user cannot see or modify that issue currently being created.
Any help is greatly appreciated! Please let me know if I can help clarify in any way.
Jason
This is a feature request which was marked as won't fix so unfortunately this will not be implemented any soon. The link to the ticket is JRA-5865.
Hi Jason,
I believe this feature is not possible to be configured in current JIRA version. I notice there is a feature request raised in Atlassian, please see https://jira.atlassian.com/browse/JRA-2764 for more details. I suggest you to vote on it for popularity issue and add yourself in watch list to keep you updated in future.
Hi Jason, have you tried the Issue Security Scheme on Jira ? It could help you.
time around it can be implemt by using javascript and REST
Hi Jason, I believe this isn't possible to do. But I found a post in the forum where it's an explanation of a possible workaround. Here it is the link:
http://forums.atlassian.com/thread.jspa?messageID=257250857
Hope this helps!
Sorry, that links to this one. Here is the possible workaround:
Yes it was, my bad, I now deleted the comment.
Sadly I can't find that thread again, but here @Amineexplains other workaround:
https://answers.atlassian.com/questions/33259/permission-to-create-specific-issue-type
Read the story
