Hello!
I have created a custom field which has its value calculated based on the date a transition happened. I would like to use this value on a report that reads data directly from JIRA's database.
I am aware that JIRA indexes the value of calculated custom fields and does not store it in the database. My question is if there is some workaround I could use in order to persist this data, somehow.
Cheers!
If you are writing it then you can do it. I don't generally use calculated field types instead I use, for instance, a number field type and do my calculation in getValueFromIssue and then call updateValue before returning my calculated result. I'm sure you could do something similar.
Thanks for your repply Justin.
Yes, it's a field I'm creating myself. I didn't understand what you mean by doing the calculation in the getValueFromIssue. If it's not a calculated field how can I perform a calculation?
Cheers!!
+---------+ +--------+ +------+ +--------+ | working | --> | review | --> | test | --> | closed | +---------+ +--------+ +------+ +--------+ | | | <------<------+<------<-----+ Fail Review Fail Test
Ok continuing my example if my workflow was as above, I would creeate a customfield call "Review Fail Count" and increment it each time that transition is followed. I would also create a "Test Fail Count" field and increment that for its transition. My pseudo calculated field wouyld be "Total Fail Count" where I would grab the values of the two previous fields and set my "Total Fail Count" field to that value and then return that result. All three fields are indexed and searchable through a number range searcher so I can query issues that failed review x number of time or test x number of times or total failures.
getValueFromIssue()
review = getCustomField("Review Fail Count").getValue(issue)
test = getCustomField("Test Fail Count").getValue(issue)
total = review + test
updateValue(total)
return total;
Thank you for your thorough explanation :)
I have one (dumb) question though: where do I put this getValueFromIssue method?
Cheers!!!
you are overriding it in your new customfield
getValueFromIssue(final CustomField field, final Issue issue)
Hi Justin,
Thanks for your answer. It indeed gives me some insight though em bit unclear about one last point that how is it updating your third custom field 'Total Fail Count'?
Do we have to write updateValue(x) function somewhere or it's a default Jira function provided and I just need to know how should I use it?
Hi Justin, I would like to know how to increase the value of a custom field with the transitions that you have in your workflow
i use a post function
Read the story
